Setting the default Traffic-Group
We have 2 F5 boxes in a cluster environment. There are 2 traffic groups configured in it and I would like to set traffic-group-2 (floating) as the default group for new objects. Presently, any object created is getting assigned to traffic-group-1(floating) and manual efforts are required to move it to group-2. Any idea how to set the default traffic-group to group-2?
You can force a different default traffic group by setting it in the partition configuration.
Go to System, Users, Partition List, and then select the partition you wish to modify. From there you can select the traffic group to be used for new objects created within that partition.
As a side note, I do not modify the Common partition, I typically create partitions to hold the objects and organize it by customer or project, and set the traffic group there.
Hope this helps!
