Patti_G_72768
Nov 05, 2013Setting maximum number of arguments in a request
Hi all, is there a way to set a maximum number of requests in ASM v11.3 or will an iRule need to be created for it? Does anyone have any suggestions?
Thanks!
- rob_carr
Cirrocumulus
While you can limit the number of HTTP requests per connection, that isn't done in ASM. It's a function of the HTTP profile, specifically the 'Maximum Requests' setting. The default is '0', which means 'unlimited'.
