Techgeeeg_28888
Nov 17, 2015Selecting a Volume in Guest Reboot
Hi Guys,
I would like to know if it is possible to select the volume from which the F5 device will reboot in case of Guest machine on a viprion as in case of individual device this can be done via Serial port connect but is it possible on Viprion guest?
Regards
- Kevin_Stewart
Employee
Can you get to the guest's shell?
tmsh reboot volume HD1.x - Techgeeeg
Yes I was getting the guest shell but in case if we are not able to get to the shell is there any way else left to achieve this??
