Emre_27149's avatar
Emre_27149
May 04, 2011
Scripted monitor is not working
I have a scripted monitor and it is working with an open ssh. But ltm is showing backend server as down when it deployed on the ltm. Do I need to change on the scripted monitor to run on the ltm properly? I have attached the scripted monitor.
Thank you.
  • What do you see when u run these from shell prompt:
    - the script (eg. /usr/bin/monitor/ocsp.mon)?
    - this command:
    openssl ocsp -issuer Mobil.pem -url http://85.235.93.61/ocsp.xuda -cert Nurettin.pem -noverify | grep "good" 2>&1 > /dev/null
    Do you put *.pem files in the same directory with the script?
  • Hi,
    it is same diretory with the script.But I am wondering that Iam gettin ok message from the ltm command line when I runned the below command. But the monitor status is still showing as down .
  • Aaron has a good article about troubleshooting LTM monitors:
    http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/TroubleshootingLtmMonitors.html
    You can also check sol12531 from AskF5:
    http://support.f5.com/kb/en-us/solutions/public/12000/500/sol12531.html
