Asim_Afzal_1147's avatar
Asim_Afzal_1147
Aug 12, 2015
Script to create TCPdump when issue happened
Hi ,
Is there any script runn when the http moniter marked down So it execute the tcpdump command and store all logs in .pcap file
  • You may want to look into using iCall to do what you're asking. You can set it up to catch certain events and then perform an action. Here's and article on it as well.
    Hope it helps.
