neeeewbie's avatar
Aug 18, 2020
Solved
script delete after upgrade
Hi guys
I need your help !
I don't know why script is deleted
script located in /var/tmp
thank you
  • Hello.
    F5 uses LVM to map their partitions.
    Only some partitions are shared between all different volumes (upgrade boot locations)
    • /shared - /dev/mapper/vg--db--sda-dat.share.1
    • /var/log - /dev/mapper/vg--db--sda-dat.log.1
    The rest of the partitions are independent for each volume (boot location).
    # lvs
      LV                       VG        Attr      LSize    Pool Origin Data%  Move Log Cpy%Sync Convert
      app.ASWADB.set.1.mysqldb vg-db-sda -wi-ao---   12.00g
      dat.log.1                vg-db-sda -wi-ao---  500.00m
      dat.maint.1              vg-db-sda -wi-a----  300.00m
      dat.share.1              vg-db-sda -wi-ao---   20.00g
      dat.swapvol.1            vg-db-sda -wi-ao--- 1000.00m
      set.1._config            vg-db-sda -wi-ao---    3.17g
      set.1._usr               vg-db-sda -wi-ao---    3.29g
      set.1._var               vg-db-sda -wi-ao---    3.00g
      set.1.root               vg-db-sda -wi-ao---  440.00m
      set.2._config            vg-db-sda -wi-ao---    3.17g
      set.2._usr               vg-db-sda -wi-ao---    3.29g
      set.2._var               vg-db-sda -wi-ao---    3.00g
      set.2.root               vg-db-sda -wi-ao---  440.00m
    As you can see above, there are two sets of var/usr/config/root partitions (1 and 2).
    These numbers correspond with the digits used in your volume (HD1.1 and HD1.2).
    # tmsh show sys software
    Sys::Software Status
    Volume  Product  Version  Build  Active    Status
    HD1.1    BIG-IP   12.1.5  0.0.6     yes  complete
    HD1.2    BIG-IP   12.1.3.4  0.0.2     no  complete
    So, your lost script should be located in the next partition:
    /dev/mapper/vg--db--sda-set.#._var
    Where '#' is the number of your previous volume.
    Regards,
    Dario.
