Scan header for mdn in irule through regex
I want to get MDN from header through scan command with regex
below is the example of header.
% set toheader {tel:+12253941228;tag=MwsjgSMFBd}
% scan $toheader {%[^:]:%[0-9]} t2 m2
1
% scan $toheader {%[^:]:%d} t2 m2
2
% puts "$m2"
2147483647
% scan $toheader {%[^:]:%s} t2 m2
2
% puts "$m2"
through 0-9 it is telling command is not correct with d its giving incorrect value.
please help quickly.
Thanks in advance
- youssef1
Cumulonimbus
I did not really understand what you wanted to do or what mdn means
but hope it will help you.
find below a simple irule that allow to retrieve value of header:
when HTTP_REQUEST_DATA { set toheader "tel:+12253941228;tag=MwsjgSMFBd" regexp {^tel:([^;]+);tag=(.*)$} $toheader -> tel tag log local0. "tel: $tel - tag : $tag" }let me know if you need more details or explain me exaclty what is the wanted result!!!
regards
