CarlT's avatar
CarlT
Feb 04, 2020
Same VIP - 2 URI's to different pools via irule - HELP
Hi Guys
I am trying to send traffic to 2 different pools depending on the http uri they are trying to reach, the below syntax will not take,
can someone assist
 if { [HTTP::uri] contains "test1.com"} {
   pool "test-pool1"
 if { [HTTP::uri] contains "test2.com""} {
   pool "test-pool2"
  • nathe's avatar
    nathe
    CarlT,
    Couple of suggestions. Firstly I think you're using the wrong command (HTTP::uri), you should be using HTTP::host.
    Secondly, you can tidy up the rule by using logic, rather than a duplicate HTTP_ REQUEST event. Using if/elseif instead. See this article for help. ​
    Hope this helps.
    N​
