stein_87754's avatar
stein_87754
Dec 23, 2011
Safari on IOS 5 randomly switches images
After ios5 was released, we started getting reports from our readers that images was randomly switched/duplicated on our website. Basicly our setup is terminating http on bigip->varnish->apache.
Ofcourse we believe its a bug in ios, but we havent been able to replicate the problem when skipping bigip and sending the http traffic straight to the varnish servers.
Please read our blog for details: http://tech.vg.no/2011/12/14/safari-on-ios-5-randomly-switches-images/
Has anyone else seen anything similar?
Stein
  • hoolio's avatar
    hoolio
    Hi Stein,
    Which LTM version are you running? Can you print out the virtual server definition using 'tmsh list ltm virtual VS_NAME'?
    Aaron
  • peloquin_71298's avatar
    peloquin_71298
    Historic F5 Account
    Hey Stein -
    Thanks for including your detailed blog post. Noah (in the blog's comments) mentioned having the same problem on a device using the Opera browser, and that disabling pipelining in the client solved his issue.
    Out of curiosity, have you tried a different browser, a la, Dolphin, Atomic, etc.? If so, were you able to replicate the issue with the BigIP in play? If not, doing so may help eliminate iOS 5 as the culprit and allow us to zero in on Safari itself. For further analysis with Safari, the Debug Console, under Safari Advanced settings may be useful.
    Joey
  • Hi,
    we're using ltm v 10.2.2-763.0
    tmsh list ltm virtual touch.vg.no
    This one gives no swapped images:
    ltm virtual touch.vg.no {
    destination 195.88.55.71:http
    ip-protocol tcp
    mask 255.255.255.255
    persist {
    source_addr {
    default yes
    pool varnish_m323_l4
    profiles {
    fastL4 { }
    snat automap
    But this one does:
    ltm virtual vg.no_m323 {
    destination 195.88.55.16:http
    ip-protocol tcp
    pool varnish_m323
    profiles {
    tcp-lan-optimized {
    context serverside
    tcp-wan-optimized {
    context clientside
    rules {
    selectively_disable_snat
    add_cookie_a55
    add_X-VG-ClientInfo
    snatpool m323_www.vg.no_snatpool
  • hoolio's avatar
    hoolio
    Can you try the L7 virtual server with a custom OneConnect profile with a /32 source mask?
    Aaron
  • That could be a problem, as OneConnect and Varnish is not the best of friends. Havent tried it in a few years, but the last time I tried OneConnect, Varnish closes the connection before the BigIP wants it to, resulting in 200OK, but empty responses to the client.
