RSA key conversion issue
Hello folks,
I am stuck at RSA conversion, can anybody help me how to do it? I want my key in the following format: -------Begin RSA Private Key-------- and customer I have the key in following format: ------Begin Encrypted Private Key------
So how can I convert it to the format I want? I am using f5 11.5 version. Please help guys. Thanking you in anticipation.
Regards, R
- R_Marc
It would appear your key is just not encrypted. If you have access to the shell, the manual for rsa gives you examples (as well as the rest of the openssl commands, very useful, IMNSHO):
To encrypt a private key using triple DES: openssl rsa -in key.pem -des3 -out keyout.pemHere are your other cipher options if you want something else:
-aes128|-aes192|-aes256|-camellia128|-camellia192|-camellia256|-des|-des3|-idea These options encrypt the private key with the specified cipher before outputting it. A pass phrase is prompted for. If none of these options is specified the key is written in plain text. This means that using the rsa utility to read in an encrypted key with no encryption option can be used to remove the pass phrase from a key, or by setting the encryption options it can be use to add or change the pass phrase. These options can only be used with PEM format output files.If you don't have access to the shell, you can do that from virtually any linux or unix box (even a windows box if openssl is installed).
