RSA + AD authentication using vmware view horizon.
hi, just configured the APM for RSA and AD authentication (Secureid_Native) and everything works good. In the APM, I configured the RSA first then followed by the AD process. My problem is this sequence, when the user is authenticated through the RSA server, he can use any other AD username and password to get access to the assigned resources, in other words, there is no binding between RSA accounts and AD accounts in the APM module. is there any way to do this kind of binding ?
thanks.
O
- Matt_Dierick
Employee
I suppose user enters his username and rsa on first login page. You can force username on the second login page so that user enters only his password.
You keep the same session variable for username. Use read only option on login page options.
Hope this help Matt
- Seth_Cooper
Employee
Hi Omar,
Do you have two separate login pages? Are the RSA userid and the AD userid the same?
Seth
- OM
Altocumulus
thanks for quick reply. well, I have 2 separate vmware view logon pages, but there is no way to force the userid as read-only in the second one (AD). Yes the RSA and AD userid are the same.
o
- OM
Altocumulus
Matt, I tried the browser logon page and yes it works as you metioned. However, when using the vmware view client (no browser) directly, the read-only option is not available in the apm. thanks.
O.
- Jeff_124628
Curious - If your users RSA ONDemand PIN is reset due to lost PIN, how does your user reset the temporary PIN given? I've not been able to get the APM to recognize that process.
