Routing traffic by URI to a server pool with https front end using iRule
I am wanting to take any https request to commonserver.domain.name and routing traffic by URI to a specific port on an underlying pool member.
https is is handled by the f5 (in a SSL Profile) and the connections are persistent once established.
The port is based of the uri coming in.
https://commonserver.domain.name/app1 -> http://<serverpool>.domain.name:xxx2/app1
https://commonserver.domain.name/app2 -> http://<serverpool>.domain.name:xxx4/app2
https://commonserver.domain.name/app3 -> http://<serverpool2>.domain.name:xx82/app3
https://commonserver.domain.name/ -> http://<serverpool3>.domain.name/defaultpage.htm
- Yoann_Le_Corvi1
Cumulonimbus
Hi
To make things simpler, can't you create one one pool for port xxx2, another for port xxx4 another for port xx82, and a last one for port 80, and assign pool directly according the URI using LTM policy ?
Yoann
- RossVermette
You could try an iRule with a Datagroup to match on a " HTTP host Header + Path" and map it to select a pool.
Note: I haven't tested this,
when CLIENT_ACCEPTED { set DEFAULT_POOL [LB::server pool] } when HTTP_REQUEST { set HOST_PATH_2_POOL [string tolower [getfield [HTTP::host] ]][string tolower [URI::path [HTTP::uri] 1 1]] set POOL_SELECT_VALUE [class lookup $HOST_PATH_2_POOL HOST_and_PATH_2_POOL_DG] if {$POOL_SELECT_VALUE eq ""} { set POOL_SELECT_VALUE [class lookup [string tolower [getfield [HTTP::host] "." 1]] HOST_and_PATH_2_POOL_DG] } #log local0.notice "HOST_PATH_2_POOL = $HOST_PATH_2_POOL" #log local0.notice "POOL_SELECT_VALUE = $POOL_SELECT_VALUE" if {$POOL_SELECT_VALUE eq ""} { set USE_POOL $DEFAULT_POOL } else { set USE_POOL $POOL_SELECT_VALUE } }Your DG would look like:
- "commonserver.domain.name/app1" := "Poolname_1",
- "commonserver.domain.name/app2" := "Poolname_2",
- "commonserver.domain.name/app3" := "Poolname_3,
- "commonserver.domain.name/" := "Default_poolname",
- Charles_Owen
I will try your suggestion tomorrow...
With limited success, I had started down a a path using a similar code with a DG using only "/appname" and used a "hammer" approach with a first irule before it like this:
Irule #1
if { [HTTP::uri] eq "" || [HTTP::uri] eq "/" } {
HTTP::redirect "http://commonserver.domain.name/" "
event disable all
Irule#2
#Check to see if the DataGroup matches a URI call
set svr_port [class match -value -- [HTTP::uri] starts_with port_fwd_applications]
#Check to see if a LB decision has already been made for this connection
if { [LB::server addr] != "" }{
#Check to see the LB port matches the DataGroup entry
if {[LB::server port] != $svr_port } {
#If the port and DataGroup dont match, remove the serverside connection and re-load-balance
LB::detach
if {$svr_port eq ""}{
#DataGroup doesn't match the URI, drop the connection
#or do something else here
drop
when LB_SELECTED {
#A new LB decision has been made, check to see if the DataGroup has fired
if {$svr_port != ""}{
#The DataGroup URI matches, check to see if the ports match
#Send the traffic to the DataGroup Port
LB::reselect node [LB::server addr] $svr_port
