Rise_77519
Apr 11, 2012routed mode config issue
I have two vlans (internal and external) and two web server in internal vlan ( exchange and blackberry servers). the exchange server default gataway was configured f5 internal ip address but blackberry server is firewall. blackberry server should make service request the exchange server from its external vip service ip address.but blacberry services is not working. but when I used snat mode then everything is ok.I think that the exchange server try to return response packet directly. Because in route mode, source and destination ip address would be in same subnet and exchange server will use directly connected interface metric instead of return packet to F5.
How can I fix the issue without using snat mode?
Many thanks.
- Michael_Yates
Hi Rise,
This is a common problem (Broken Routes) in situations like yours and your options are limited.
1. Move one of the devices onto a non-LTM owned Subnet (which may or may not resolve your issue (Depends on the communication behavior).
2. If you are on v11 you can attempt a Sideband Connection.
3. Enable SNAT and try and compensate for the behavior with the X-Forwarded-For Header insertion of the true Client IP Address in the Packet Headers.
Hope this helps.
