WTW_280077's avatar
WTW_280077
Aug 30, 2017
Route traffic based on use case
Is it possible to use iRule to route traffic to one pool when there is a file upload and other HTTP traffic to a default pool?
  • Hi WTW,
    Is it possible to use iRule...
    Everything is possible with iRules... 😉
    To develop a tailordered iRule for your Web Application, you have to find out how the upload functionality is implemented. Some Web Application are using a HTTP-POST request targeting a specific file (e.g.
    ./upload.php
    ) to upload the data and some others Web Applications are using the HTTP-PUT request (e.g. Webdav Clients).
    Depending on your Web Application an iRule may look like this:
    Example 1:
        if { [string tolower [HTTP::path]] ends_with "upload.php" } then {
            pool upload_pool
            pool default_pool
    Example 2:
        if { [HTTP::method] equals "PUT" } then {
            pool upload_pool
            pool default_pool
    Cheers, Kai
