Angelo
Aug 08, 2012rewrite body of web-site
Hi is it possible to write body of a web-site where the code says http i need to change it to https. can anyone assist...
- Michael_Yates
Hi Angelo,
It is absolutley possible.
You can do this using the base LTM Functionality within a Stream Profile or a combination of a blank stream profile and an iRule using the STREAM::expression command.
Stream Profile
Local Traffic -> Profiles -> Other -> Stream
- Parent Profile: stream
- Source: http
- Target: https
Stream Expression
Go to the location above and create a "blank" stream profile
- Source: leave.blank
- Target: leave.blank
Apply the blank stream profile to the Virtual Server and then apply the iRule example on the STREAM::expression Wiki Page.Example which replaces http:// with https:// in response content Prevents server compression in responses when HTTP_REQUEST { Disable the stream filter for all requests STREAM::disable LTM does not uncompress response content, so if the server has compression enabled and it cannot be disabled on the server, we can prevent the server from sending a compressed response by removing the compression offerings from the client HTTP::header remove "Accept-Encoding" } when HTTP_RESPONSE { Check if response type is text if {[HTTP::header value Content-Type] contains "text"}{ Replace http:// with https:// STREAM::expression {@http://@https://@} Enable the stream filter for this response only STREAM::enable } }
Hope this helps. - Angelo
Thanks micheal it's working.. the only thing is now the requirment has changed again... not the only need one URI changed so how can i rewrite the rule to only convert HTTP://www.test.com to HTTPS://www.test.com - nitass
Employee
e.g.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.79:80 ip protocol 6 rules myrule profiles { http {} stream {} tcp {} } } [root@ve10:Active] config b pool foo list pool foo { members 200.200.200.101:80 {} } [root@ve10:Active] config b rule myrule list rule myrule { when HTTP_REQUEST { STREAM::disable HTTP::header remove "Accept-Encoding" } when HTTP_RESPONSE { if {[HTTP::header value Content-Type] contains "text"}{ STREAM::expression {@http://www.test.com@https://www.test.com@} STREAM::enable } } } response from server [root@ve10:Active] config curl http://200.200.200.101/test.html start of content hello world url is http://www.test.com/something another url is http://www.googe.com/ end of content response from bigip [root@ve10:Active] config curl http://172.28.19.79/test.html start of content hello world url is https://www.test.com/something another url is http://www.googe.com/ end of content
