Raju_Kavad_3290's avatar
Raju_Kavad_3290
Aug 03, 2017
Solved
require ip detail for hitting wideip
how to check hit on GTM wideIP from which ip hitting that wideip
we are running with 9.4x version on f5 GTM thanks in advance
  • You should be able add an iRule with something like log local0. "Client IP is [IP::addr[IP::client_addr]"
  • Jeff_Maddox_394's avatar
    Jeff_Maddox_394
    Historic F5 Account
    • Raju_Kavad_3290's avatar
      Raju_Kavad_3290
      you may use TCPDump tcpdump on external port 53, it will be easy, if TCPDUMP allowed
