san_239682
Mar 07, 2016Replacing SFP module on F5 viprion 2400 device
Can anyone please provide detailed steps on how to replace SFP module on F5 viprion 2400 device. Thanks in advance
- Brad_Parker
Cirrus
They aren't any different than any other SFP. You pull the existing one out and put a new one in.
- san_239682
Thank you Parker. Do we need to halt or reboot the system to do this process which is prod device. - Brad_Parker
Cirrus
No need to halt or reboot. If the SFP is failed already, no harm no foul. If its part of a LACP trunk just for sanity sake you may disable the interface before you pull the old one and insert the new one. These are hot swap-able components. Its more of a matter do you have traffic currently flowing through it? And if so, will disabling the interface allow traffic to flow through another interface.
- Brad_Parker_139
Nacreous
- san_239682
Thank you Parker. Do we need to halt or reboot the system to do this process which is prod device. - Brad_Parker_139
Nacreous
