Replacement for GTMPARSE or GTMLOAD on v11
I want to edit configuration of GTM on v11 on the command line that is more easy to develop, with which command I can accomplish this?
- What_Lies_Bene1
tmsh is your friend, here's a incredibly long manual: http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmsh-11-4-0.html.
- Cristian_Daniel
The answer is that in version 11 that there is three ways to configure GTM the first is by GUI, second by tmsh, and third by modify the configuration files. I used to use the gtmparse -l or gtmload to upload a modified configuration file, also is used to force the synchronization. The replacement for this use of the third method is to make a tmsh load sys config gtm-only and that will load the GTM config of the modified file. The answer for my question is here: http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote_11_0_0_ltm.html
Thank you,
- hoolio
And to verify the gtm config without loading it you can use:
tmsh load sys config gtm-only verify
