Remode Desktop not Load Balancing Round Robin
I have F5 - LTM with below h/w CPU Status Index Temp(degC) Fan Speed(rpm) 1 33 15913
Platform Name C112 BIOS Revision OBJ-0433-xx Build: 1.12.137.0 10/30/2012 Base MAC 00:23:e9:70:d2:c0
-- in partition called = scms_prod created one Virtual Server = Type Standard for VIP on port 3389 as per the document from F5 http://www.f5.com/pdf/deployment-guides/f5-microsoft-remote-desktop-services-dg.pdf and having two Nodes with SNAT and Persistance Profile is rdp and NO-iRule Method- Round Robin. But connection on Pool are not load balancing . what could be the problem and how to troubleshoot.
output of ..in partition is below show /ltm persistence persist-records mode msrdp all-properties
Sys::Persistent Connections
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 2 Mode msrdp Value AVPR-PMPS Age (sec.) 23 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 1 Mode msrdp Value AVPR-PMPS Age (sec.) 23 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 0 Mode msrdp Value PSMConnec Age (sec.) 2 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
remaining.
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 1 Mode msrdp Value PSMConnec Age (sec.) 5 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 3 Mode msrdp Value PSMConnec Age (sec.) 5 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
msrdp - VIP-RDP%2:3389 - NODE-1%2:3389TMM 2 Mode msrdp Value PSMConnec Age (sec.) 1 Virtual Name /scms_prod/PIM-PSM-MGT_3389_vs Virtual Addr VIP-RDP%2:3389 Node Addr NODE-1%2:3389 Pool Name /scms_prod/PIM-PSM-MGT_3389_pool
Total records returned: 6
if someone can help.
I tried to change it to Least connection also, still it is not working..
no body responded ...
- mikeshimkus_111Historic F5 Account
Hi Neeraj,
I'm guessing AVPR-PMPS and PSMConnec are your user names? Did both those users have an existing session on node 1 before you started testing? You will need to kill the terminal services session on the Remote Desktop each time before you connect to see if load balancing is working. Once you have a TS session on the server, the msrdp profile will bypass load balancing and send the connection to that server every time.
Mike
Hi mike, appreciate your response over.
I tried to stop all the sessions. when all the connections becomes Zero, I checked again and found that when users started getting connection ratio of connection to be 80:10, sometimes 80:05, but as per round robing every new connection to be sent to different server, however I have tried the least connection as well. here to mention that I captured one more log also where all the users were different - different users.
regards, Neeraj Jagetia
- mikeshimkus_111Historic F5 AccountWhat are AVPR-PMPS and PSMConnec, are those domain names?
Mike, this is the one-App-portal identifier from where the user click to connect some application and RDP is being initiated to open the browser to access resources like other app / putty /etc.. this is cyber arc PIM system.
What I'm getting at is I think there may be a limit to the number of characters the msrdp persistence profile can use for the persistence key. If those 2 values are domain names, that could explain why they aren't unique.
as you wrote above , to kill the RDP / terminal services sessions. how to do that ?
