T0nyP's avatar
T0nyP
Icon for Cirrus rankCirrus
Jan 03, 2024
Solved
Recommended Persistence for F5 working as ISP-LB ( ISP Load Balancing )
Just want to ask based on your implementation experience what is recommended persistence for ISP Load Balancing? ( Source IP Persistence or Destination IP Persistence )
Thanks.
  • i cant find related f5 kb on that.
    however, ideal ISP load balancing should persist source&&destination ip address.
    hash persistence allows to create such persistence object.
    if persisting on source ip address only, access from 1 client will only uses 1 isp.
  • Hash persistence is better choice than source ip address.
    Destination ip address is definitely not proper for ISP LB.
    It will make, for example access to youtube, goes through only 1 ISP
    • T0nyP's avatar
      T0nyP
      Hi zamroni777, thank very much for your input. Do you see any related F5 KB article that hash persistence is recommended for LB of ISP?
