lipos_54863
May 18, 2009Receive String problem
I'm trying to create a regular monitor that would monitor a website with:
Send String: GET / HTTP/1.0
Receive String: Welcome Page
When I do telnet "IP of the Node" 80, I get text that is including "Welcome Page" string, but the monitor seems to be down.
When I use a Receive String of "div" the monitor goes up.
Is there something wrong with formatting of the Receive String for my request?
I guess the configuration should be pretty straightforward, but still I'm stuck.
I tried GET /Default.aspx HTTP/1.1 with similar recieve strings and still nothing.
Also, if I use my default monitor of:
Receive String: 200 OK
Everything works well, but I need to monitor some text from the website.
Any ideas?
- mjaved_62370
1- Ok i did enable debug can when put 200 in receive string without any inverted commas virtual server comes up below is what i can see in debug
17:07:53.845091: (_recv_active_service_ping): addr=::ffff:10.2.110.164:80 send=GET / HTTP/1.1
Host:
Connection: Close
regexp=200 recv=HTTP/1.1 400 Bad Request
Content-Type: text/html
Date: Thu, 30 Jul 2009 07:10:14 GMT
Connection: close
Content-Length: 42
2- Now when i replace 200 with DMZ below is what debug looks like, note at this stage virtual server is down. Cant see any string coming back.
17:10:13.180514: (_main_loop): time to ping addr=::ffff:10.2.110.164:80 pending=0
17:10:13.180559: (_send_active_service_ping): addr=::ffff:10.2.110.164:80
17:10:13.180578: (_connect_to_service): creating new socket for addr=::ffff:10.2.110.164:80
17:10:13.180633: (_connect_to_service): addr=::ffff:10.2.110.164:80 connect: Operation now in progress
17:10:13.182033: (_main_loop): wfd selected for addr=::ffff:10.2.110.164:80 pending=1
17:10:13.182057: (_send_active_service_ping): addr=::ffff:10.2.110.164:80
17:10:13.182089: send_active_service_ping: addr=::ffff:10.2.110.164:80 writing GET / HTTP/1.1
Host:
Connection: Close - hoolio
The app is sending a 400 error indicating a bad request. I'd guess it doesn't like the empty host header. It might also be an issue with the carriage return / line feeds on the monitor. You could try configuring the actual host header value the server expects in the send string and experiment with one or two \r\n's at the end:
GET / HTTP/1.1\r\nConnection: Close\r\nHost: \r\n
GET / HTTP/1.1\r\nConnection: Close\r\nHost: \r\n\r\n
GET / HTTP/1.1\r\nConnection: Close\r\nHost: actualhost.example.com\r\n
GET / HTTP/1.1\r\nConnection: Close\r\nHost: actualhost.example.com\r\n\r\n
Once you get a 200 OK response, the pool member(s) will be marked up and the VIP will process requests.
Aaron - mjaved_62370
Thanks it works with version 9.4.7 HF1
