Re: Connecting to F5 using SSH via Ansible
Paulius -- Apologies for the late reply. I was tied up with another engagement. Thank you for the suggestion. I did see that git-hub post & did try the stuff mentioned there before posting here. Unfortunately, it did not help. The issue started happening after I upgraded the f5-collections. I rolled back the f5-collections to 1.22, but that still did not fix the issue. I donot think the issue was with the collections itself but a combination of collection, ansible & python version. To get this working again, I had to create a virtual environment & use that for ansible. Here are the steps
mkdir ~/tmp
mv ~/.ansible ~/tmp
mv ~/.cache ~/tmp
mv ~/.config ~/tmp
mkdir -p ~/workspace/venv
cd ~/workspace/venv
/usr/local/bin/python3.9 -m venv ./ansible-2.9.17
Wait for the virtual environment to get created
source ~/workspace/venv/ansible-2.9.17/bin/activate
pip install --upgrade pip
pip list
This should show you default packages with pip
pip install ansible==2.9.17
pip install paramiko
pip list
ansible-galaxy collection install -r requirements.ymlThe requirements file is as follows
collections:
# --- F5 Collections ---
- name: f5networks.f5_modules
version: 1.22.0
- name: f5networks.f5_bigip
# --- Required for clean STDOUT ---
- name: ansible.posix
# --- Required for IP management ---
- name: ansible.utils
# --- Required for json_query ---
- name: community.general
...I also switched to paramiko for ssh connectivity instead of ansible's built in module.
