George_San_Pedr's avatar
George_San_Pedr
Aug 04, 2005
rate limiting per user/IP
I am trying to rate limit my tcp connections based on client source/destination IPs so that a given user is limited to 15k/sec. Any suggestion on how to achieve this based on irules and rate shaping?
Thanks,
George
  • Ken_Wong_48678's avatar
    Ken_Wong_48678
    Historic F5 Account
    Hi Colin,
    This is Ken, I also encounter a simlar case. How about if I do not know the exactly ip of the user but I know the range? Should I pre-defined the client ip to rateclass mapping?
    There are may be a class C subnet, I need to create 254 rateclass to map with client ip. Is there any loop can be used in rule to simplify the rule. Thanks!
    Regards,
    Ken
  • No need to loop. If you want to mask off an entire Class C subnet, you can use the slash notation in the comparison. Try this:
    when CLIENT_ACCEPTED {
      if {[IP::addr "[IP::client_addr]/24" equals "aaa.bbb.ccc.0/24"]} {
        log local0. "[IP::client_addr] being sent to rateclass class1"
        rateclass class1
    The IP::client_addr is probably what you want to be going with as well when comparing.
    Also, make sure you are using the IP::addr command when comparing IP Addresses, it makes sure it's not a string compare but a actual IP Address comparison which is more optimal and accurate.
    If you had multiple subnets you need to monitor, you could create an IP Address Data Group and use the matchclass command in conjunction with that data group.
    -Joe
    Ken_Wong_48678
    Historic F5 Account
    Hi Joe,
    Thanks for your information. But actually, I want to ensure every ip in a class C subnet has same separate rateclass not share, such as following
    192.168.0.1/24 -> class1
    192.168.0.2/24 -> class2
    192.168.0.254/24 -> class254
    Can I use rule to perform this settings? TIA
    Regards,
    Ken
    Ken_Wong_48678
    Historic F5 Account
    Hi Colin,
    It's great. I just look for your secondary suggestion. It is a streaming services that I need to make sure every ip (customer) has received bandwidth.
    Could you tell me a little bit more of set rclass [concat class [lindex {$octets} end]]. If I am not using the last octet, what syntax I can use to replace "end".
    Finally, where can I find these "split, concat and lindex..." command information? I cannot find these in BIG-IP menu, I believe there are many useful command I can use in the irule. Pls. let me know where I can find these resources. Thanks!
    Regards,
    Ken
