Gavin_104961
Dec 08, 2011[Question] Volume seeking of ARX by iControl
Dear All, Does anybody know iControl be able to get the Volume name that ARX just wrote to? If iControl can do it, Which command should I invoke? Thanks!
- April_Spence_8Ret. EmployeeHey Gavin,
Im moving this over to the Storage group to hopefully get you an answer soon:).
April - Jim_McCarron_44Historic F5 AccountGavin,
Somehow this slipped through the cracks. Can you be a little more specific on what you need? ARX does support an iControl API, and the first use of this API is for File Change Notification tracking. I am not sure if this is inline with your request? The API itself is documented here:
http://devcentral.f5.com/wiki/iControl.ARX.ashx
And some further detail on getting File Change Notifications via a perl script can be found here:
http://devcentral.f5.com/wiki/iControl.ARXFileChange.ashx
Jim - wangh_97509Historic F5 AccountYou can use iControl to get volume names and other configuration and statuses from ARX. You can find the perl example at http://devcentral.f5.com/wiki/iControl.ARX-Volume-Info.ashx. If you use C, you can search "iControl Assembly ARX" in DevCentral and download the latest assembly.
Hengli
