N__197982
Sep 27, 2015Question on some CLI command help.
Folks, Which CLI commands can I use to monitor the hits to pools members?
When we disable one or two members I just want to confirm that hits are going to the third member. I check the GUI here and it does not show me any increase.
regards, N.
- lipanpan_224208
I think you can ues irule to meet your demand. when LB_SELECTED { log local0. "[IP::client_addr] [IP::local_addr] [LB::server addr]" } The rule will show you the client IP, the Virtual server ip, and the Server IP in /var/log/ltm.
- Brad_Parker
Cirrus
tmsh show ltm pool members
