John_Heyer_1508's avatar
John_Heyer_1508
10 years ago
Proper syntax for using quotes in monitors send/recv?
For http monitors, we generally look at our application's status page. This returns the output from various tests, with both the test name and result surrounded by quotes. It's my understanding that quotes need to be prefaced with a backslash in order for them to be properly processed.
I didn't have any problems with this until I tried "load sys config" from TMSH, and realized it's not liking the syntax:
(Active)(/Common)(tmos) create ltm monitor http MyMon send 'GET /MyApp/Status\r\n' recv '\"httpStatus\":\"OK\"'
(Active)(/Common)(tmos) load sys config
Loading configuration...
  /config/bigip_base.conf
  /config/bigip_user.conf
  /config/bigip.conf
01070642:3: Monitor /Common/MyMon parameter contains unescaped " escape with backslash.
Unexpected Error: Loading configuration process failed.
