Fredrik_Johnsso's avatar
Fredrik_Johnsso
8 years ago
Problems with IdP Automation
We have been trying for a while to get the IdP Automation to work. The Metadata URL is accessible by BIG-IP, we have verified that using curl in an SSH terminal. Every time BIG-IP wants to update/create the IdP, the following error message is written to the saml_automation.log file:
Error in create/modify of idp connector /Common/[IdP-name-based-on-config] Error: result { result_code 17237778 result_message "01070712:3: apm aaa saml-idp-connector /Common/[IdP-name-based-on-config] unable to parse metadata file /tmp/testout.xml" }
The following error message is written to the LTM log:
f5 err mcpd[4958]: 01070712:3: Caught configuration exception (0), apm aaa saml-idp-connector /Common/[IdP-name-based-on-config] unable e to parse metadata file /tmp/testout.xml.
Unfortunately the file /tmp/testout.xml does not exist. During the update process another file, /tmp/xml_meta.xml, is created but it gets immediately deleted.
Has anyone seen this behaviour before and managed to solve it?
