Keith_Odom_1073
Jan 18, 2005Problems connecting to F5 BIGIP 1000 through iControl SOAP interface.
I have run into a problem connecting to an F5 BIGIP 1000 machine through the iControl SOAP interface. This problem is occurring in a customer environment and I do not have one that I can test against.
The code that is interacting with the F5 is written in Perl and has been tested against other versions of BIGIP. Are there differences between the iControl interface with the 1000?
I was going to look at the sample code in the 4.x sdk to see if I am doing something wrong, but I can't seem to get the sdk downloaded correctly.
Any ideas?
Thanks,
Keith
- Loc_Pham_101863Historic F5 AccountKeith,
About the SDK download problem, I don't see anything wrong since I just downloaded the SDK and extracted it.
Once you're able to download the 4.6.2 SDK, try using the sample apps in the SDK to connect to the iControl SOAP portal again.
Specifically, what problems are you seeing? If you can provide the exact interfaces/methods you're having problems with, perhaps we can take a closer look.
Loc
