Using PHP to connect to iControl REST interface
Problem this snippet solves:
Using PHP 7 (and newer) with the GuzzleHttp library to connect to the REST interface.
How to use this snippet:
Install the GuzzleHttp library if you need to and include the autoloader. This is a regular step or process for any modern PHP application.
Code :
Tested this on version:
12.1Published Oct 03, 2018
Version 1.0emilorol_373618
Joined May 05, 2019
