Problem with VLAN on a trunk partition
Hello,
I have a problem that is taking days to resolve. I am stuck. How can I troubleshooting the VLAN configuration on the interface. The configuration looks fine, but I am pretty sure, the Bigip is not tagging this specific VLAN on the interface, as I don't see any MAC for this VLAN on the switch. While others work fine. The VLAN es the 423. I simplified the config. Others VLANs with different tag ID work fine.
net route-domain /CUSTOMER-DMZ/CUSTOMER-DMZ { id 16 vlans { /CUSTOMER-DMZ/CUSTOMER-DMZ-B-S_1 } } net self /CUSTOMER-DMZ/B-S-CUSTOMER-DMZ_I { address 172.17.197.103/27 traffic-group /Common/traffic-group-local-only vlan /CUSTOMER-DMZ/CUSTOMER-DMZ-B-S_1 } net self /CUSTOMER-DMZ/B-S-CUSTOMER-DMZ_1_Floating { address 172.17.197.104/27 traffic-group /Common/traffic-group-1 vlan /CUSTOMER-DMZ/CUSTOMER-DMZ-B-S_1 } net vlan /CUSTOMER-DMZ/CUSTOMER-DMZ-B-S_1 { description CUSTOMER-DMZ-B-S_1 interfaces { Backend_Trunk { tagged } } tag 423 }
Thanks, Regards,
- Hamish
Cirrocumulus
At first glance it looks OK.
You can easily verify by performing a tcpdump on the trunk/interface and specifying the '-e' parameter (With appropriate filters in place so you don't get over whelmed with info).
tcpdump will then show you the VLAN TAG being used on the packet.
What makes you think it's not being tagged?
H
- Hamish
Cirrocumulus
Can you post the switch config for that port-channel? (Use backticks to format it as code though in the posting please)
H
- Fmartin_116699
interface Port-channel3 description fonesixbap04_backend switchport switchport trunk allowed vlan 311-322,410-425,500-525,601-625,1034,1044,1045 switchport trunk allowed vlan add 1055,1065,1070-1076,1101,2044,2045,2055,2065 switchport trunk allowed vlan add 2070-2076 switchport mode trunk switchport nonegotiate end
- Fmartin_116699
sorry I don't know how to paste with the rigth format.
- Fmartin_116699
Delete the full configuration. Route domain included. Load the same configuration. And it's working fine. I am pretty sure, the problem was the first time when I created the VLAN. the error of "untagged" just made something that , even when I rectified, and the config looked fine. It didn't tag anymore.
