Problem with connecting using f5 vpn on Ubuntu/Linux; stuck on "Connecting..."
As for /var/log/svpn.log
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, =====================================
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Location: /opt/f5/vpn/svpn
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Version: "7220.2022.0308.1"
2023-02-23,13:41:04:158, 160816,160816,svpn, 0,,,, Locale: C
2023-02-23,13:41:04:158, 160816,160816,svpn, 48,,,, current log level = 63
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 132, ------------------,
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 133, [main], getuid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 134, [main], getgid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 135, [main], geteuid, 0
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 136, [main], getegid, 1000
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 137, [main], HOME, /home/karim
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 139, [main], version, 7220.2022.0308.1
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 141, ------------------,
2023-02-23,13:41:04:158, 160816,160816,svpn, 1, , 148, [main], Current sigprocmask: 0x14a3dec0
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 46, ReadProperties() Select retruns the pipe data size : , 3915,
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 51, ReadProperties() Pipe Read lopp ,
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 55, ReadProperties() read() , 3915, <VERY LONG LINE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 62, ReadProperties() reading pipe : , 3915, <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 72, ReadProperties() after reading the data from pipe : , 3915, <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:158, 160816,160816,svpn, 48, , 83, ReadProperties() Data send by Edge Client over pipe : , <VERY LONG LINE IDENTICAL TO ONE ABOVE>
2023-02-23,13:41:04:160, 160816,160816,svpn, 48, , 99, ReadProperties(), ,
2023-02-23,13:41:04:160, 160816,160816,svpn, 48, , 99, ReadProperties(), q0, 3C786D6C617474723E3D
// many lines filled with what seems like randome nubers after like so:
// I removed them from the log to fit them in a single message, the number
// here is an example
2023-02-23,13:41:04:163, 160816,160816,svpn, 48, , 99, ReadProperties(), q34, 697679696EDA67DA9E6D7796F976D97E697A6F97E6697A6D96A0F
2023-02-23,13:41:04:163, 160816,160816,svpn, 48, , 99, ReadProperties(), q77, 3D
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), <xmlattr>, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), session_id, 5df83964, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_sidhash, 5df83964, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_z, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_name, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), host0, 127.0.0.1, 127
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), port0, 44444, 44444
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_type, VPN, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_connect, auto, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_protocol0, https, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), idle_session_timeout, 5400, 5400
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), firepassserver0, /Common/<VPN_GROUP>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ipv4_0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ipv6_0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_dtls, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns0, 192.168.168.49 1.1.1.1, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), wins0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnssuffix0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnsregisterconnection0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dnsusednssuffixforregistration0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), splittunneling0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), lan0, 192.168.2.7/255.255.255.255 192.168.2.12/255.255.255.255 192.168.168.0/255.255.255.0 192.168.80.18/255.255.255.255 192.168.60.31/255.255.255.255 192.168.155.21/255.255.255.255 192.168.2.23/255.255.255.255 192.168.30.20/255.255.255.255 192.168.155.50/255.255.255.255, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), lan6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludesubnets0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludesubnets6_0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dns_split0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), excludedomainnames0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocalsubnetaccess0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocaldnsserversaccess0, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), allowlocaldhcpaccess0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), add2hosts0, <SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.2.23|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.2.23|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.30.20|<SUB_DOMAIN>.<COMPANY_NAME>.<TLD>|192.168.80.18, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_donotwarnuser, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), clientformicrosoftnetworks0, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), fileandprintersharingformicrosoftnetworks0, 2, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), enforcednsorder0, ON, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_disableclientcerts, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), dontreportpolicy0, TRUE, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), processtimeout0, -1, -1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), hdlc_framing, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), autoreconnectifdropped0, yes, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tcp_reconnect_timeout0, 900000, 900000
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tcp_reconnect_delay0, 200, 200
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), trafficcontrol0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_powermanagement, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), displayedbandwidth0, 100000000, 100000000
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_msg0, NO, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_networktunnelenabled, yes, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_optimizedappsenabled, no, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), minimize_after_connect0, YES, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_ctrlchannelenabled, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ur_isessionenabled, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_msg_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_connect_fallback_msg_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_routing_changes_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_process_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_registry_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_config_error_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_os_patch_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_ie_patch_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), display_pf_check_txt0, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_host0, <COMPANY_DOMAIN>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), tunnel_port0, 443, 443
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), browser_pid, 160796, 160796
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), version, 2.9, 2
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), , , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), client_pid, 160796, 160796
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), HOST, <COMPANY_DOMAIN>, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), PORT, 443, 443
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), UseDefaultGateway, OFF, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalSubnetAccess, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalDHCPAccess, 1, 1
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), AllowLocalDNSServersAccess, 0, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), LAN, 192.168.2.7/255.255.255.255 192.168.2.12/255.255.255.255 192.168.168.0/255.255.255.0 192.168.80.18/255.255.255.255 192.168.60.31/255.255.255.255 192.168.155.21/255.255.255.255 192.168.2.23/255.255.255.255 192.168.30.20/255.255.255.255 192.168.155.50/255.255.255.255, 192
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), ExcludeSubnets, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), EnforceRouteTable, , 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 1, , 320, SSLVpn::SetProperties(), txqueuelength, 100, 100
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 1369, SSLVpn::svpn(), Open(), setuid, 1000, 0
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 662, CString ResolveHostNameGetFirstIp(const CString&), Resolved '<COMPANY_DOMAIN>' to <COMPANY_IP>
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 716, void SSLVpn::ConfigureTunnelChannel(), U_TUNNEL_HOST=<COMPANY_DOMAIN>
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 11, UTunChannel::UTunChannel(), Initializing...
2023-02-23,13:41:04:166, 160816,160817,svpn, 48, , 42, UTunChannel::CloneDevice(), Opening utun device
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, , 296, UTunChannel::IsDeviceAvailable(), Device is available
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, , 751, SSLVpn::ConfigureTunnelChannel(), Tun device will be used
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UChannelChain.cpp, 55, , enter, 0x80f: U_ENABLE_SOCKET_CHANNEL U_ENABLE_SSL_CHANNEL U_ENABLE_PROXY_CHANNEL U_ENABLE_HTTP_CHANNEL U_ENABLE_PPP_EMULATION_CHANNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 48,,,, USSLChannel::USSLChannel:RAND_status(1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UF5FramePacketizerChannel.cpp, 293, UF5FramePacketizerChannel::setProperties(), fast framing will be used
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 593, UHTTPChannel::setProperties(), m_bFastPPPMode, true
2023-02-23,13:41:04:167, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 597, UHTTPChannel::setProperties(), m_bUseISession, false
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, --------- Initial State --------
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, Address Netif
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 127.0.0.1/8 lo( 1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.1.10/24 wlp5s0( 3)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.122.1/24 virbr0( 4)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.19.0.1/16 br-63dcbff36084( 6)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.20.0.1/16 br-74660eaa12c1( 7)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.18.0.1/16 br-9ebcc5f112e6( 😎
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.22.0.1/16 br-9fdcc1944e6d( 9)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.23.0.1/16 br-3e8ed22008b1(10)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.21.0.1/16 br-4c314f5c6ea9(11)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.25.0.1/16 br-5202490322d8(12)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.17.0.1/16 docker0(13)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::1/128 lo( 1)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::ed58:cb1a:4464:9231/64 wlp5s0( 3)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:e7ff:fe94:e6/64 br-63dcbff36084( 6)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:e2ff:fed4:1fd9/64 br-74660eaa12c1( 7)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::42:95ff:fe06:54cd/64 br-9ebcc5f112e6( 😎
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::5c94:c1ff:feec:be64/64 veth5ae8a4c(15)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::a44a:ffff:fe33:1781/64 veth0d86702(17)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::38c1:2dff:fef1:f19c/64 veth30a69c9(19)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::2c13:38ff:fe1d:1e67/64 vethe81d240(21)
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, Destination Gateway Flags Netif Expire Proto Preferred Source Address
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 0.0.0.0/0 192.168.1.1 UG wlp5s0(3) 0 RTPROT_DHCP
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 169.254.0.0/16 link#4 U virbr0(4) 0 RTPROT_BOOT
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.17.0.0/16 link#13 U docker0(13) 0 RTPROT_KERNEL 172.17.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.18.0.0/16 link#8 U br-9ebcc5f112e6(8) 0 RTPROT_KERNEL 172.18.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.19.0.0/16 link#6 U br-63dcbff36084(6) 0 RTPROT_KERNEL 172.19.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.20.0.0/16 link#7 U br-74660eaa12c1(7) 0 RTPROT_KERNEL 172.20.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.21.0.0/16 link#11 U br-4c314f5c6ea9(11) 0 RTPROT_KERNEL 172.21.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.22.0.0/16 link#9 U br-9fdcc1944e6d(9) 0 RTPROT_KERNEL 172.22.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.23.0.0/16 link#10 U br-3e8ed22008b1(10) 0 RTPROT_KERNEL 172.23.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 172.25.0.0/16 link#12 U br-5202490322d8(12) 0 RTPROT_KERNEL 172.25.0.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.1.0/24 link#3 U wlp5s0(3) 0 RTPROT_KERNEL 192.168.1.10
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, 192.168.122.0/24 link#4 U virbr0(4) 0 RTPROT_KERNEL 192.168.122.1
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::1/128 link#1 U lo(1) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#8 U br-9ebcc5f112e6(8) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#15 U veth5ae8a4c(15) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#17 U veth0d86702(17) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#6 U br-63dcbff36084(6) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#19 U veth30a69c9(19) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#21 U vethe81d240(21) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#7 U br-74660eaa12c1(7) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, fe80::/64 link#3 U wlp5s0(3) 0 RTPROT_KERNEL
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, ::/0 fe80::a5a:11ff:fe42:d3b0 UG wlp5s0(3) 0 RTPROT_RA
2023-02-23,13:41:04:167, 160816,160817,svpn, 0,,,, --------- End --------
- KarimElsayad247Feb 23, 2023
Altostratus
2023-02-23,13:41:06:167, 160816,160817,svpn, 48, , 1505, SSLVpn::svpn(), We're connecting...2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1508, SSLVpn::svpn(), ServerReachable! Let's connect!2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1171, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1186, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 1187, SSLVpn::ConnectChannels(), Let's try to connect Tunnel Channel2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 662, CString ResolveHostNameGetFirstIp(const CString&), Resolved '<COMPANY_DOMAIN>' to '<COPMANY_IP>'2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, <COMPANY_IP>2023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 642, SHORT GetMTUForPPP(CLinuxRouteTable&, const CString&, bool), Best route to APM (<COMPANY_IP>): <COMPANY_IP>/32 192.168.1.1 U wlp5s0(3) 0 RTPROT_UNSPEC 192.168.1.102023-02-23,13:41:06:168, 160816,160817,svpn, 48, , 647, SHORT GetMTUForPPP(CLinuxRouteTable&, const CString&, bool), Physical interface MTU=1500, desired tunnelMRU=13842023-02-23,13:41:06:168, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 703, UHTTPChannel::setProperties(), m_bFastPPPMode, true2023-02-23,13:41:06:168, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 118, UF5PPPEmulationChannel::Open(), enter2023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 152023-02-23,13:41:06:168, 160816,160817,svpn, 48, /EventHandlerImplBase.h, 239, , Unknown event, EVENT_TYPE_FP_SESSION_GET_CURRENT, 02023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 32023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 222023-02-23,13:41:06:168, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 02023-02-23,13:41:06:319, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 232023-02-23,13:41:06:320, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 02023-02-23,13:41:06:320, 160816,160817,svpn, 48, /USSLChannel.cpp, 342, , socket receive timeout set (seconds), 302023-02-23,13:41:06:320, 160816,160817,svpn, 48,,,, USSLChannel::Open() - select return 12023-02-23,13:41:06:320, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 305, UHTTPChannel::beginConnection(), hdlc_framing=no2023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 35, CLinuxEventHandler::HandleEvent(), enter, 12023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 43, CLinuxEventHandler::HandleEvent(), EVENT_TYPE_SELECT_CLIENT_CERT2023-02-23,13:41:06:575, 160816,160817,svpn, 1, /LinuxEventHandler.cpp, 1009, LinuxEventHandler::verifyServerCert(), Not launched from CLI ignoring cert check2023-02-23,13:41:06:575, 160816,160817,svpn, 48, /LinuxEventHandler.cpp, 68, CLinuxEventHandler::HandleEvent(), exit with, 32023-02-23,13:41:06:981, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 423, UHTTPChannel::beginConnection(), find header pos, 952023-02-23,13:41:06:982, 160816,160817,svpn, 48, /UHTTPChannel.cpp, 467, UHTTPChannel::beginConnection(), server returned HTTP code, 2002023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 484, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_EXCH_ALGO, ECDH2023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 489, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_CIPHER_ALGO, AESGCM(128)2023-02-23,13:41:06:982, 160816,160817,svpn, 1, /USSLChannel.cpp, 494, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_HASH_ALGO, AEAD2023-02-23,13:41:06:982, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Dead, switching to Establish2023-02-23,13:41:07:186, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1077, UF5PPPEmulationChannel::DispatchAction(), LCP up2023-02-23,13:41:07:186, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1086, UF5PPPEmulationChannel::DispatchAction(), Negotiated remote MRU: 12512023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1104, UF5PPPEmulationChannel::DispatchAction(), Negotiated local MRU: 12512023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Establish, switching to Authenticate2023-02-23,13:41:07:187, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 857, UF5PPPEmulationChannel::ChangePhase, Current link phase is Authenticate, switching to Network2023-02-23,13:41:07:394, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1726, UF5PPPEmulationChannel::ProcessControlMessage(), Unknown protocol, 328552023-02-23,13:41:07:394, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1734, UF5PPPEmulationChannel::ProcessControlMessage(), Sending Protocol-Reject2023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1113, UF5PPPEmulationChannel::DispatchAction(), IPCP up2023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1125, DispatchAction, Local address: 192.168.3.1272023-02-23,13:41:07:596, 160816,160817,svpn, 48, /UF5PPPEmulationChannel.cpp, 1126, DispatchAction, Remote address: 1.1.1.12023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 484, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_EXCH_ALGO, ECDH2023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 489, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_CIPHER_ALGO, AESGCM(128)2023-02-23,13:41:07:596, 160816,160817,svpn, 1, /USSLChannel.cpp, 494, USSLChannel::Open(), U_TUNNEL_TRANSPORT_SECURITY_HASH_ALGO, AEAD2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 841, SSLVpn::OpenTunnelChannel(), Proxy,2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 857, SSLVpn::OpenTunnelChannel(), IP addresses: , 192.168.3.127, 1.1.1.12023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 868, SSLVpn::OpenTunnelChannel(), IPv6 addresses: , ,2023-02-23,13:41:07:596, 160816,160817,svpn, 48, , 1193, SSLVpn::ConnectChannels(), -------------------------------------2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 1194, SSLVpn::ConnectChannels(), Let's try to connect PPPD Channel2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 255.255.255.2552023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 32023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 32023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 288, UTunChannel::setProperties(), IP, mtu, 192.168.3.127, 1.1.1.1, 12512023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 109, UTunChannel::Open(), Opening utun interface2023-02-23,13:41:07:597, 160816,160817,svpn, 48, , 42, UTunChannel::CloneDevice(), Opening utun device2023-02-23,13:41:07:598, 160816,160817,svpn, 48, , 178, UTunChannel::Open(), Device opened, tun0, 412023-02-23,13:41:07:602, 160816,160817,svpn, 48, , 1228, SSLVpn::ConnectChannels(), communication channels opened2023-02-23,13:41:09:170, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,13:41:09:618, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.12023-02-23,13:41:09:618, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,13:41:10:170, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.1...more than 3700 lines of same thing...2023-02-23,14:08:54:351, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 412023-02-23,14:08:55:351, 160816,160817,svpn, 48, , 803, CLinuxRouteTable::GetBestRoute2, 1.1.1.12023-02-23,14:08:55:351, 160816,160817,svpn, 48, , 268, CLinuxRouteTable::GetIfaceAddr2, IFace, 41```For all these logs, I've replaced sensitive info such as specific ips, company domains and subdomains, and vpn group with generic tokens.Something worth noting is that I could patch the hosts file manually, add manually add some routes to my ip table pointing at vpn (at tun0 address) and I would connect to those specific domain names, however I wouldn't be able to receive callbacks from them, and f5vpn would still display connecting state.
