Derek_Nelson_10
Aug 24, 2005Problem with Certificate Hash verification
Hi all.
I'm having a problem with verifying connections to a particular proxy that "requires" a client cert. The proxy is inserting the Certificate Serial Number and Certificate Hash into the HTTP Header.
Trying to use this iRule:
if (http_header("SSLClientCertSerialNumber") == one of Cert_SN and http_header("SSLClientCertHash") == one of Cert_Hash) {
log "MutualSSL accepted from:${client_addr}"
use pool web-pool
else {
log "MutualSSL Denied from:${client_addr}"
discard
Class Cert_Hash String
XX:YY:ZZ:C2:9A:B9:B5:20:BE:DA:1E:3F:C7:A8:A6:29
XXYYZZC29AB9B520BEDA1E3FC7A8A629
xx:yy:zz:c2:9a:b9:b5:20:be:da:1e:3f:c7:a8:a6:29
Cert_SN String
xx:yy:zz:44:91:79:b3:ae:7e:9d:6c:49:22:c2:6a:ef
xx:yy:zz:39:b1:7a:f3:2c:29:e7:00:64:62:a5:86:b6
(xyz's inserted manually here...)
Currently none of the hashes above work, and the serial numbers do work. I checked this by removing the appropriate condition in the rule individually.
SOL1910 from ASK F5 KB shows the hash format as above. I have tried (as you can see) both upper and lower case as the article shows lower case for serial numbers but upper case for the hashes. Anyone know if this is case sensitive?
I have got the hashes by exporting the certificate in DER, Base64 PEM, and PKCS formats and tried all the separate hashes (using the command "md5 certificate.crt" and converting the format inserting the colons) to no avail.
What I'm trying to achieve is to restrict my "mutual SSL" B2B connection to only a select few certificates, rather than allowing any certificate signed by a specific CA like in the ca-bundle.crt (Client Trusted CAs File)...
Thanks,
- Derek.
- Martin_MachacekHistoric F5 AccountDerek,
to troubleshoot your problem add to your rule logging of the cert hash extracted from the header, like this:if (http_header("SSLClientCertSerialNumber") == one of Cert_SN and http_header("SSLClientCertHash") == one of Cert_Hash) { log "MutualSSL accepted from:${client_addr} hash: " + http_header("SSLClientCertHash") use pool web-pool } else { log "MutualSSL Denied from:${client_addr} hash: " + http_header("SSLClientCertHash") discard }
That will allow you to find out what you need to match. - Derek_Nelson_10
Thanks mmac.
I'd just figured out the problem yesterday actually and hadn't got around to posting the fix. I managed to capture the hash by using an "ssldump -AnP -i internal -k cert.key -p password | grep SSLC" command
Thanks for the help - this would have made the troubleshooting a lot easier! I'll incorporate the concatenation into my logs. It seems not to interpret the ${client_addr} for some reason, but if I do multiple log entries it seems to work OK.
The problem I had was I was trying to compare the md5 hash of the PEM certificate. It appears that browsers "present" the certs in DER format, the BIG-IP then md5 hashes that. The hash is also converted to upper-case hex with colons after every 2 characters. Unlike the Serial Number, which is in a similar format, but in lower-case hex.
Cheers,
- Derek.
