Shay_Ben-David1
Feb 26, 2009Problem with an irule
i am having some problem with an irule that should update the timeout of the persist record based on a SIP method, the deletion of the persist based on the if argument is going OK, but the adding of the persist with different timeout is not:
when SIP_REQUEST {
if {[SIP::method] == "BYE"} {
session delete sip [SIP::call_id]
session add sip [SIP::call_id] 20
the session can be replaced with persist as well, and the same result is being shown.
thanks
- hoolio
What do you see if you run 'b persist all show all' for the corresponding record after adding the record from the iRule? Can you post an anonymised copy of your VIP and related profiles using 'b virtual VIRTUAL_NAME list' and 'b profile PROFILE_NAME list'?
Thanks,
Aaron - Shay_Ben-David1
when BYE sent, the persist is removed and another one comes in place, but the timeout for this persist comes from the default profile (180 second) and not from the irule.
virtual incoming-sip-v4 {
pool server-v4-pool
destination 10.106.1.1:5060
ip protocol udp
rules Incoming_SIP_ipv4
profiles
sip-v4
sip_calls
udp_ipv4_immediate
persist sip-callid-v4
profile udp udp_ipv4_immediate {
defaults from udp
idle timeout immediate
datagram lb enable
allow payload disable
profile sip sip-v4 {
defaults from sip
terminate bye disable
profile stats sip_calls {
defaults from stats
field1 172.10.10.2
field2 172.10.10.3
field3 172.10.10.4
profile persist sip-callid-v4 {
defaults from sip_info
mode sip
timeout 1800
sip info "Call-ID"
across services disable
across virtuals enable
across pools disable
} - Shay_Ben-David1
any idea why the irule is not function as it should ? - tovy_93828
hi, i also try some irule exactly like this and found the same situation, where the persist timeout is being taken from the default profile and not from the irule, another thing that i notice is that the irule seems to work with the deletion of the persist when the "if" condition accure, so i also don't know why its not working, maybe someone from devcentral could help me understand this ?
when SIP_REQUEST {
log.local0 "method: {[SIP::method] "
persist delete sip [SIP::call_id]
persist add sip [SIP::call_id]
