Problem to Get Information
Good day. I run this command curl -k -u user:password -H “Content-Type: application/json” -X GET
With my login,password and ip server.
And I return this error.
http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
Object not found!
The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again.
Error 404
Tue May 19 13:06:44 2015
I need change any configuration inside F5-Big-IP?
- samstep
Cirrocumulus
Hi Douglas,
Which version of BIG-IP are you running? iControlREST is only available from v11.5.0+
You should read:
https://devcentral.f5.com/wiki/iControlREST.HomePage.ashx
Hope this helps,
Sam
