Cesar_01_134968's avatar
Cesar_01_134968
9 years ago
Problem ProxySSL with two pools.
I have a VS with ProxySSL enabled (profile SSL client and server), and two pools with HTTPS (A_pool and B_pool). I configure the A_pool as default pool in VS and works correctly. But when I change to B_pool, through a iRule, show a error. How can I change the default pool through a iRule?
Very thanks.
  • It seems that your code is correct.
    I tried this code and it works for me
     if {[HTTP::path] contains "jta"} {
       log local0. "my_pool_a is selected for path [HTTP::path]"
       pool my_pool_a
       log local0. "my_pool_b is selected for path [HTTP::path]"
       pool my_pool_b
    Have you applied the irule to your VS ?
    Remark: you can remove the "default pool" configuration from the "ressources" and just apply your irule and try again.
    You can also check your log in /var/log/ltm
    Regards
  • Hi JT,
    Attach my iRule,
    when HTTP_REQUEST { if { [HTTP::path] contains "/B/" } { pool B_pool } else { pool A_pool } }
    Thanks.
