Problem creating wildcard ssl profile with tmsh
I'm trying to create a client ssl cert using tmsh and am running into a bit of an issue.
I'm trying to post this:
tmsh create ltm profile client-ssl STAR.DUMMYHOST.COM_CLIENT-SSL { app-service none cert ".dummyhost.com_2015-11-13.crt" cert-key-chain add { ".dummyhost.com_2015-11-13" { cert "*.dummyhost.com_2015-11-13.crt" chain Trustedcert.crt key ".dummyhost.com_2015-11-13.key" } } chain Trustedcert.crt.crt defaults-from clientssl key ".dummyhost.com_2015-11-13.key" passphrase none}
and I'm getting this error message: Syntax Error: the "create" command does not accept wildcard configuration identifiers
Would seem to me that because my ssl cert is starting with '', tmsh is unable to read the '' as part of the name and is under the impression its a wildcard. So I tried using '\' as escape char in front of every '*' as well as not using the quotes to no avail.
Any help would be appreciated.
- Kevin_Stewart
Employee
The only thing in a wildcard cert that needs a wildcard () is the CN value. The certificate file name, and the LTM certificate objects should not have a star () in the name.
