Problem changing Partitions in Perl
I'm trying to list all the virtual servers in Test1. I'm trying a couple of different calls to try to get the partition (folder) to change to /Test1, but it doesn't seem to work.
The portion that retrieves the list of virtual servers does work, but only retrives the virtual servers in /Common.
Any ideas/suggestions would be greatly appreciated.
!/usr/bin/perl
use strict;
use SOAP::Lite;
use MIME::Base64;
use Data::Dumper;
my $sHost = "1.0.0.21";
my $sUID = "admin";
my $sPWD = "f5rules";
my $sProtocol = "https";
my $sPort = 443;
my $debug = 1;
SOAP Transport
sub SOAP::Transport::HTTP::Client::get_basic_credentials {
return "$sUID" => "$sPWD";
Subroutins
BEGIN - Sub to extract System Info
sub iSystemInfo
my ($SoapRequest,$soapResponse,$version);
my($iURI,$iCREQ,$iCREQVAR) = @_;
print "\n\n10-VAR Systest: $iURI - $iCREQ - $iCREQVAR\n";
$SoapRequest = SOAP::Lite
-> uri($iURI)
-> proxy("https://$sHost:$sPort/iControl/iControlPortal.cgi");
$soapResponse = $SoapRequest->$iCREQ($iCREQVAR);
$SysInfo = $soapResponse->result;
print "soapResp: $soapResponse\n";
print "SYSINFO: $SysInfo\n";
return $SysInfo;
END - System Info Sub
BEGIN - Sub to extract System Info for Array Values
System::Session::set_active_folder
sub iSystemInfo_Array
my($iURI,$iCREQ) = @_;
print "\n\n1-Array Systest: $iURI - $iCREQ\n";
-> uri($iURI)
$soapResponse = $SoapRequest->$iCREQ();
@SysInfo = @{$soapResponse->result};
return @SysInfo;
$sHost = "1.0.0.13";
Gets partition list
$GetActPart = iSystemInfo('urn:iControl:Management/Partition',"get_active_partition", "");
$SetActPart = iSystemInfo('urn:iControl:Management/Partition',"set_active_partition", "Test1");
$GetActPartx = iSystemInfo('urn:iControl:Management/Partition',"get_active_partition", "");
$GetActPart1 = iSystemInfo('urn:iControl:System/Session',"get_active_folder", "");
$SetActPart1 = iSystemInfo('urn:iControl:System/Session',"set_active_folder", "/Test1");
$GetActPartx1 = iSystemInfo('urn:iControl:System/Session',"get_active_folder", "");
@VirtualList = iSystemInfo_Array('urn:iControl:LocalLB/VirtualServer',"get_list");
foreach (@VirtualList) { print "Virtual: $_\n"; }
print "Partition: SET:$SetActPart GET: $GetActPart GET1: $GetActPartx\n";
print "Partition1: SET:$SetActPart1 GET: $GetActPart1 GET1: $GetActPartx1\n";
output of script:
1-Array Systest: urn:iControl:LocalLB/VirtualServer - get_list
Virtual: /Common/V_TEST_35_443
Virtual: /Common/V_TEST_30_80
Virtual: /Common/vs_1_0_0_30_53_gtm
Virtual: /Common/FWD_virtual
Virtual: /Common/V_TEST_32_80
Virtual: /Common/V_TEST_31_80
Virtual: /Common/TLS_TEST
Partition: SET: GET: Common GET1: Common
Partition1: SET: GET: /Common GET1: /Common
- Have you tried calling Management.Partition.get_partition_list() and/or Management.Folder.get_list() to get the list of available options? Keep in mind that top level folders are the same as the parititons. We originally developed partitions as a way to segment off configuration but we then added support for sub-folders within the partitions.
I wrote a tech tip a while back about folders (https://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1086495/iControl-101-24--Folders.aspx). You'll likely want to turn on the recursive query state to return a full listing instead of just the items in the "current" folder.
-Joe - Townsie_105233Historic F5 AccountI've been through that doc, I'm just missing something..
I'm using the following with the script above to retrieve the partition list:
@Partition = iSystemInfo_Array('urn:iControl:Management/Partition',"get_partition_list");
foreach (@Partition) {
my %Partition_hash = %{$_};
$partition_name = $Partition_hash{partition_name};
print "Partition name: $_ - $partition_name\n";
push (@Partition_list, $partition_name);
output:
Partition name: Management::Partition::AuthZPartition=HASH(0x8cc1e1c) - Common
Partition name: Management::Partition::AuthZPartition=HASH(0x8cb9710) - Test1
Partition name: Management::Partition::AuthZPartition=HASH(0x8cb9620) - Test2 - gdehaudt_116857
I've the same problem.
Does someone have a solution ?
Gilles
- Cory_del_Mar_67
I am having the same problem, any ideas why?
- Cory_del_Mar_67
It does not printout all pools in all partitions - it only did for /Common,
!/usr/bin/perl use SOAP::Lite + trace => qw(method debug); use SOAP::Lite; ---------------------------------------------------------------------------- Validate Arguments ---------------------------------------------------------------------------- my $sHost = '192.168.1.2'; my $sPort = '443'; my $sUID = 'blaster'; my $sPWD = 'hhhjkk123'; my $sPool = $ARGV[0]; my $sNodeAddr = $ARGV[1]; my $sProtocol = "https"; sub usage() { die ("Usage: toggle [pool [addr:port]]\n"); } if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") ) { usage(); } if ( ("80" eq $sPort) or ("8080" eq $sPort) ) { $sProtocol = "http"; } ---------------------------------------------------------------------------- Transport Information ---------------------------------------------------------------------------- sub SOAP::Transport::HTTP::Client::get_basic_credentials { return "$sUID" => "$sPWD"; } $Pool = SOAP::Lite -> uri('urn:iControl:LocalLB/Pool') -> readable(1) -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi"); $PoolMember = SOAP::Lite -> uri('urn:iControl:LocalLB/PoolMember') -> readable(1) -> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi"); ---------------------------------------------------------------------------- Attempt to add auth headers to avoid dual-round trip ---------------------------------------------------------------------------- eval { $Pool->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '') ); }; eval { $Pool->transport->http_request->header ( 'Authorization' => 'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '') ); }; ---------------------------------------------------------------------------- support for custom enum types ---------------------------------------------------------------------------- sub SOAP::Deserializer::typecast { my ($self, $value, $name, $attrs, $children, $type) = @_; my $retval = undef; if ( "{urn:iControl}Common.EnabledState" == $type ) { $retval = $value; } return $retval; } ---------------------------------------------------------------------------- Main logic ---------------------------------------------------------------------------- if ( "" eq $sPool ) { ------------------------------------------------------------------------ No pool supplied. Query pool list and display members for given pool ------------------------------------------------------------------------ $soapResponse = $Pool->get_list(); &checkResponse($soapResponse); @pool_list = @{$soapResponse->result}; &showPoolMembers(@pool_list); } elsif ( "" eq $sNodeAddr ) { ------------------------------------------------------------------------ Pool supplied, but now member so display given pools members ------------------------------------------------------------------------ &showPoolMembers($sPool); } else { ------------------------------------------------------------------------ both pool and member supplied so toggle the specified member. ------------------------------------------------------------------------ &togglePoolMember($sPool, $sNodeAddr); } ---------------------------------------------------------------------------- Show list of pools and members ---------------------------------------------------------------------------- sub showPoolMembers() { my (@pool_list) = @_; my @member_state_lists = &getPoolMemberStates(@pool_list); $rdate = `date`; print "\n\n$rdate\n"; print "Available pool members\n"; print "\n======================\n"; $i = 0; foreach $pool (@pool_list) { print "pool $pool\n{\n"; @member_state_list = @{@member_state_lists[$i]}; foreach $member_state (@member_state_list) { $member = $member_state->{"member"}; $addr = $member->{"address"}; $port = $member->{"port"}; $session_state = $member_state->{"session_state"}; print "$pool:$addr:$port:$session_state\n"; } print "}\n"; $i++; } } ---------------------------------------------------------------------------- Toggle a specified pool member ---------------------------------------------------------------------------- sub togglePoolMember() { my ($pool_name, $member_def) = (@_); ------------------------------------------------------------------------ Split apart node:port ------------------------------------------------------------------------ ($sNodeIP, $sNodePort) = split(/:/, $member_def, 2); if ( "" eq $sNodePort ) { $sNodePort = "0"; } $member = { address => $sNodeIP, port => $sNodePort }; -------------------------------------------------------------------- Query enabled state for given Node:port -------------------------------------------------------------------- $pool_member_state = &getPoolMemberState($pool_name, $member); ---------------------------------------------------------------- Set the state to be toggled to. ---------------------------------------------------------------- my $toggleState = "STATE_DISABLED"; if ( "STATE_DISABLED" eq $pool_member_state ) { $toggleState = "STATE_ENABLED"; } elsif ( "STATE_ENABLED" eq $pool_member_state ) { $toggleState = "STATE_DISABLED"; } else { die("Couldn't find member $member_def in pool $pool_name\n"); } $MemberSessionState = { member => $member, session_state => $toggleState }; push @MemberSessionStateList, $MemberSessionState; push @MemberSessionStateLists, [@MemberSessionStateList]; ---------------------------------------------------------------- Toggle the state. ---------------------------------------------------------------- $soapResponse = $PoolMember->set_session_enabled_state ( SOAP::Data->name ( pool_names => ( [$pool_name] ) ), SOAP::Data->name ( session_states => [@MemberSessionStateLists] ) ); &checkResponse($soapResponse); print "Pool Member $pool_name {$sNodeIP:$sNodePort} state set from '$pool_member_state' to '$toggleState'\n"; } ---------------------------------------------------------------------------- returns the status structures for the members of the specified pools ---------------------------------------------------------------------------- sub getPoolMemberStates() { my (@pool_list) = @_; $soapResponse = $PoolMember->get_session_enabled_state ( SOAP::Data->name(pool_names => [@pool_list]) ); &checkResponse($soapResponse); @member_state_lists = @{$soapResponse->result}; return @member_state_lists; } ---------------------------------------------------------------------------- Get the actual state of a given pool member ---------------------------------------------------------------------------- sub getPoolMemberState() { my ($pool_name, $member_def) = (@_); my $state = ""; @member_state_lists = &getPoolMemberStates($pool_name); @member_state_list = @{@member_state_lists[0]}; foreach $member_state (@member_state_list) { my $member = $member_state->{"member"}; if ( ($member->{"address"} eq $member_def->{"address"}) and ($member->{"port"} eq $member_def->{"port"}) ) { $state = $member_state->{"session_state"} } } return $state; } ---------------------------------------------------------------------------- checkResponse ---------------------------------------------------------------------------- sub checkResponse() { my ($soapResponse) = (@_); if ( $soapResponse->fault ) { print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n"; exit(); } } - woliver_163458
Altocumulus
I realize this is an old question, but it's what popped up on google when I ran into the same issue.
In the provided example, you're doing this... $SoapRequest->set_active_partition(Test1);
What I had to do to get it working was... $SoapRequest->set_active_partition(SOAP::Data->name('active_partition')->value('Test1'));
- jagdish_narvan1
hi,
can someone please update the toggle perl script, with partition query. How to run toggle on different partitions, thanks.
