PaulONL's avatar
PaulONL
Mar 02, 2020
Problem between F5 CGNAT and Graylog Server
Dear F5 Community,
I have F5 model Model: BIG-IP i7600 with version: Version: 14.1.0.3 Build 0.0.6 running as CGNAT.
And I installed Graylog server version: 3.0 free edition to receive the LSN CGNAT logs.
I followed document below to send the CGNAT logs from F5 CGNAT to the Graylog server as HSL, but Graylog can not receive the CGNAT logs from F5.
https://techdocs.f5.com/en-us/bigip-14-0-0/big-ip-cgnat-implementations-14-0-0/using-cgnat-logging-and-subscriber-traceability.html
Everyone used to have such experience? and how to solve the issue?
Please kindly advise.
Thank you.
  • Hi Nag,
    Thank for your information.
    Yes, i used to use the command: tcpdump
    I can see message sending to Graylog server, but at the server Graylog does not receive the logs.
    May you please have any more advice?
    Thank with regards,
    PaulONL
  • NAG's avatar
    NAG
    I didnt come across such a problem.
    However, best way to troubleshoot to find the root cause is to take packet captures::
    Here is the command you could use to get packet captures F5:
    tcpdump -vvni 0.0:nnnp -s0 host <IP_Address_of_Graylog> and port <PORT_of_Graylog> -w /var/log/file_name.pcap
    Hope this helps,
    Nag
