Imran_62568
Jul 29, 2009problem after upgrade from 9.4.6 to 10.0.1
i upgraded the one of my hardisk in ltm to 10.0.1 and the configuration file i have loaded is from 9.4.6. (a ucs file)i got all the configuration in 10.0.1 but failover is not working,
Presently unit 2 is active. even i switch of the unit 2, unit 1 is still standby, however sync i perfect. And when i'm saying unit2 for force to standby the unit is going standby, and unit 1 is still remain standby.
when i change the setting in the unit 1 as single unit instead of redundant pair unit1 is getting active as usual.
What must b the issue?
- Cspillane_18296
Hello,
I'm sure you've fixed this issue by now, but in caser you haven't:
Check the settings under System>High Availability>Redundancy. Unit 1 should have the 'Redundancy State Preference' of 'Active' and unit 2 should have it set to 'Standby'.
Also check the settings under System>High Availability>Network Failover, particularly 'Perr Management Address' and the 'Unicast' settings.
Good luck! - hoolio
Hi Chris,
Thanks for the info. It's worth noting that there is a bug in handling incorrect multicast network failover configuration:
SOL10742: A non-multicast address in the multicast network failover address field causes the sod memory to leak
https://support.f5.com/kb/en-us/solutions/public/10000/700/sol10742.html
Manual Chapter: Configuring High Availability
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos_management_guide_10_0_0/tmos_high_avail.html1051374
Aaron
