chandru_14815's avatar
chandru_14815
Jan 31, 2009
Power Shell script to monitor active node
Hi Joe,
Can you help me with a power shell script to know which node is currently active and the config sync details for both the F5 Big-ips?
Can this result be shown in an html page
-Chandru
  • Can you explain what you mean by "which node is currently active". Are you referring to a pool member? Isn't the idea that they are all active? If you can specify exactly what you are looking for, I could probably get you something going.
    -Joe
  • Thanks Joe!
    I am looking for sync status and which node is active in the cluster
    Hope this helps
  • hoolio's avatar
    hoolio
    I think chandru is asking how he can determine which BIG-IP in an active standby pair is active and whether the configuration on the two units are in sync.
    Aaron
  • Don_MacVittie_1's avatar
    Don_MacVittie_1
    Historic F5 Account
    Hey chandru,
    Here are a couple articles on this topic and some sample source in Java, conversion to C is straightforward, though if you've not done such a conversion before I can lend a hand.
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=125
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=133
    Hope that helps!
    Don.
  • Hi Don,
    I have not done this conversion before. Can you help me convert this?
    Your help is much appreciated
    Chandru
