SMTP scripted monitor
Problem this snippet solves:
This scripted monitor performs a health check of an SMTP service
How to use this snippet:
Create a new file:
/usr/bin/monitors/smtp.script
Add the expect script below. Customize
@localhost to a valid email account on the servers being monitored. As dsirrine suggested, you could use a local account where the mailbox has been redirected to /dev/null.Create a custom scripted monitor which calls the expect script:
Local Traffic >> Monitors >> Create
Type Scripted Name my_smtp_scripted_monitor File Name /usr/bin/monitors/smtp.script
Add the monitor to them SMTP monitor pool and test with the service up, down and account enabled and disabled.
If you enable debug on the scripted monitor, the output is written to:
/var/log/SCRIPTED_....log Ex: SCRIPTED__Common_smtp_scripted_monitor.\:\:ffff\:10.1.0.100..25.log
Code :
expect 220 send "HELO localhost\r\n" expect "250" send "MAIL FROM: @localhost\r\n" expect "250" send "RCPT TO: @localhost\r\n" expect "250" send "DATA\r\n" expect "354" send "SUBJECT:F5 LTM SMTP Health Check\r\n" send "\r\n" send "This e-mail is generated by the SMTP health check by the F5 LTM.\r\n" send ".\r\n" expect "250" send "quit\r\n" expect "221"
Published Mar 12, 2015
Version 1.0dsirrine_24840
Altostratus
Joined January 29, 2009
