chandru_14815
Jan 31, 2009Power Shell script to monitor active node
Hi Joe,
Can you help me with a power shell script to know which node is currently active and the config sync details for both the F5 Big-ips?
Can this result be shown in ...
Feb 05, 2009
Can you explain what you mean by "which node is currently active". Are you referring to a pool member? Isn't the idea that they are all active? If you can specify exactly what you are looking for, I could probably get you something going.
-Joe
