chandru_14815
Jan 31, 2009Power Shell script to monitor active node
Hi Joe,
Can you help me with a power shell script to know which node is currently active and the config sync details for both the F5 Big-ips?
Can this result be shown in ...
Don_MacVittie_1
Feb 20, 2009Historic F5 Account
Hey chandru,
Here are a couple articles on this topic and some sample source in Java, conversion to C is straightforward, though if you've not done such a conversion before I can lend a hand.
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=125
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=133
Hope that helps!
Don.
