power save mode
I'm installing a 6900 HA pair , but one of these systems stays in power save mode . (2nd unit doesn't give any problem)
When it boot, on LCD the message "press button to start from power save mode" appaers . However when doing this , nothing seems to happen .
Using the console cable, i see systems boot but stops at following message (see hereunder) . Does anybody know what's happening here ? I can find only little info on power save modes. (most of it for firepass systems)
copy from console screen hereunder :
"CFE
Press Ctrl-c to stop autoboot: [1] Loader:elf Filesys:raw Dev:flash1.linux File:x Options:(null) Loading: 0x80001000/4889355 0x804aab0b/263941 Entry at 0x80289000 Starting program at 0x80289000
RUN! Using baud rate of 19200
--- Press ( for Command Menu, or for Host console.
"D104 "
- Kevin_Stewart
Employee
I'm guessing that "power save mode" is a byproduct of a bigger issue. From the console, do you see it continuously trying to reboot? If yes, the error looks like a potential filesystem problem (hard drive or flash). Does it respond to any commands?
I would suggest one of the following approaches:
Follow this guide to completely rebuild the hard drive: http://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip_getting_started_guide_10_1_0/bip_gs_app_diskinit.html1029399, and/or
Open a support case and/or potentially RMA the unit.
- Richard__HarlanHistoric F5 Account
I would try calling support sound like there is a problem. You can also try connecting to the AOM and forcing the Unit to rebooting the AOM. But again I would call support.
http://support.f5.com/kb/en-us/solutions/public/9000/400/sol9403.html?sr=31203738
- werner_v_113449
no , it doesn't boot continiously . It stays at that prompt.
I can interupt the boot sequence (crtl-C) & go into boot menu . But can't find much info about how to continue from there on ...
- hoolio
As Kevin suggested, I'd open a case on this. You could also try reloading the AOM firmware:
sol13846: Recovering from the CFE> prompt and AOM boot failure http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13846.html
You could also try running the EUD hardware diagnostic:
Supplemental Document: Field Testing BIG-IP Hardware: 1600, 3600, 3900, 6900, 8900, 8950, 11000, 11050, EM4000: http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/EUD-M-12-10-0.html
Aaron
- werner_v_113449
Thanks ,
i'll be trying the recovery from CFE procedure next friday (i need to go on-site for this ) ; If it fails , i'll be opening an case at F5 .
in any case thanks for the help.
