dw_888_212625
Nov 05, 2015possible to add request headers in LTM
kindly advise how can we add the below 2 request headers to load balancer
x-forwarded-port https
- Renato
Altostratus
You can use the iRule method HTTP::header. Use it in HTTP_REQUEST event if you want to modify the data sent to server side, otherwise use in HTTP_RESPONSE to send to client side.
Example:
when HTTP_REQUEST { HTTP::header insert X-Forwarded-Port [TCP::local_port] } - dw_888_212625
Hi, im sorry, we are trying to achieve the following... x-forwarded-port https
- Renato_166638
You can replace [TCP::local_port] with any information, but I suppose that it expects a number. Aren't you talking about the X-Forwarded-Proto instead?
- Henrik_Gyllkran
Just create a custom http profile (or modify the existing one) and add "x-forwarded-port:https" to the Request Header Insert parameter.
