Kureen_329835's avatar
Kureen_329835
Aug 08, 2017
Pool statistics current connections
What's considered a current connection? We have four nodes in a pool and have it set to round robin but it seems to not spread the connections around. We will have a node with 100 connections and the other three have as little as 10 to 15. What's considered a connection? How do we make sure we get these connections spread across the nodes evenly?
  • Hello,
    "Current Connection" corresponds to all opened connections (socket) between the F5 and Pool Member.
    There are many factors that can explain why you don't have even connection between pool members.
    I recommend you to read the following article and determine why you have this behavior.
    https://support.f5.com/csp/article/K10430
    Hope it helps,
    Regards
