Pool or Node Monitoring and redirection
I have F5 ASM and need somehow to monitor pool or node and if status of one or another is "down" then redirect traffic to other pool and make http:redirect.
I didnt find anything in forum search...
Itried to do something like this:
if { [active_members My_pool1] < 1 } {
pool My_pool2
HTTPS::redirect "https://abc.com/one"
But this is not working... :/ I asked F5 support do I need LTM license in order to use this commands (active_members, LB:seerver, etc) but they could not tell me that..
Can someone suggest what can be done in order to monitor pool/node and then take action based on monitor result ?
thank you in advance
Vytautas.
- George_Watkins_Historic F5 AccountHi Vytautas,
Give this a shot:when LB_FAILED { HTTP::redirect "https://abc.com/one" }
You probably don't want to select a pool then send a redirect to client. I would do one or the other. I can't say for sure that this will work on an ASM standalone, but I'd lean towards yes. Give it a shot.
-George
