Pool Members down with custom monitor
When I am adding custom monitor pool members are going down.But if I add basic https monitor servers going up.
I am using : Send String as GET \"/main/system/webdev_staging/SCADA/getTagValue?tagPath=Gateway/Maintenance%20Mode HTTP/1.0 \r\n\r\n\" Receive String false Receive Disable String true But when I am using is working.
What are the changes I need to do ?
- cjunior
Nacreous
Shri@,
What are the result when you request directly to member?
I note that you are wrote:
Receive String: false
Receive Disable String: trueIf you mean that "true" and "false" are only possible values from query result, it will cause (UP/Disabled) to members when "true".
See: https://support.f5.com/csp/article/K12818
Regards.
- cjunior
Nacreous
Hi, I apologize, but i gave you mistakes. Please, try this with HTTP/1.1 and host name. It should makes the job.
Send string: GET /main/system/webdev_staging/SCADA/getTagValue?tagPath=Gateway/Maintenance%20Mode HTTP/1.1\r\nHost: somehostvaluehere\r\nConnection: close\r\n\r\n Receive string: false Receive disable string: true
