huudat_20099's avatar
huudat_20099
Aug 20, 2007
Pls help-> health monitor for each website
I have been configuring BIG-IP LTM 3400 for load balancing with multiple website use host header names IIS 6. I don't know how to configure health monitor for each website. Pls help me.
I have 2 domain on each server:
IP Add: 10.0.0.10: 80; domain: www.abc1.com
www.abc2.com
IP Add: 10.0.0.11:80; domain: www.abc1.com
www.abc2.com
IP Add: 10.0.0.12:80; domain: www.abc1.com
www.abc2.com
  • hoolio's avatar
    hoolio
    You can post monitor related questions in the new forum:
    Click here
    In general, you can configure an HTTP 1.1 formatted send string for a monitor that includes the domain of the server in the Host header:
    send string:
    GET /index.html HTTP/1.1\r\nHost: www.abc1.com\r\nConnection: close\r\n
    receive string:
    200 OK
    See SOL1096 (Click here) for details. Note that in 9.x, I think the final \r\n sequence is added automatically so you don't need to add two carriage return/line feeds.
    Aaron
  • Hi, I configured as following:
    http_monitotor1
    send string:
    receive string:
    200 OK
    and http_monitotor2
    end string:
    GET /index.html HTTP/1.1\r\nHost: www.abc2.com\r\nConnection: close\r\n
    receive string:
    200 OK
    and assigned it to pool, it is Ok-> it let me know members pool worked well
    But I wonder that how can I recognize on BIG-IP LTM one Website down or not? Can I recognize it on BIG-IP ? thanks for your help.
  • hoolio's avatar
    hoolio
    You can configure one pool per web application and then only use the web app-specific monitor for that pool. If the monitor fails, the node in only that pool gets marked down. It doesn't matter whether the pool member is defined in multiple pools.
    Aaron
