jyseg_48587's avatar
jyseg_48587
Aug 22, 2017
Please help persist idle timeout 0 irule
Some users want to make persist idle timeout 0 Please check irule applicable
class internal {
network 10.100.28.0/16
when CLIENT_ACCEPTED {
if { [matchclass [IP::client_addr] equals $::internal] } {
log local0. "internal_user :: [IP::client_addr]"
   persist sticky 0
Persist sticky 0
I do not know if this part is accurate.
Please help.
  • If you are trying to disable persistence, you can use "persist none". What is the functional requirement i.e., how do you want the connections to be processed for 10.100.28.0/16 ?
